VEtech97
Hi all. first time posting, have lurked a few times though.
I've essentially been tasked to turn a raisin back into a grape. we have a 97-2 that was sent to the dealer for a supply pump. once the supply pump was installed the dealer tech diagnosed the engine also needed injectors. upon repair he discovered that water had got into the fuel system and voided the warranty. my company collected the machine tore down then let it sit out in the elements for almost 3 months before tasking me with it.
what I've done: new common rail, intake clean out, fuel filters, oil change, injectors, MAF sensor, valve adjust, injector trim codes. (not in that order)
once everything was back together I couldn't get the machine to run, it was throwing MAF codes. replacing the sensor eliminated the MAF code and the machine would run. but once the throttle was touched it would die. Data monitor showed low rail pressure but I was getting solid pressure to the supply pump from the filter. I unplugged the pressure sensor and she would run for about a minute. the tech at the dealer told me that it needs a supply pump learn because it has a new pump and injectors. when performing the supply pump learn, it failed. now the machine runs at an idle, but I have no throttle and the test fails overtime. tech at dealer says he doesn't know where to go from here. so neither do I.
if anyone has any suggestions, id deeply appreciate it. thanks.
