John V
Hey, I've got an older kubota excavator with a d1402b engine. about 4500 hrs on machine. Engine occasionally pushes coolant to the overflow bottle and runs low on coolant, so I keep an eye on the temp gauge. When it runs hot I'll check the level in the radiator and it'll be low. Top it off and runs fine until it's lost more.
Replaced the water pump as I saw a small drip from that. No other leaks noticeable except for the coolant getting pushed to the overflow bottle. The coolant in the overflow bottle is dirty/mixed with oil. I recently did an oil change in the past 30hrs and the oil was good (not a milkshake).
I don't think this engine has an oil cooler. I'm guessing that leaves a blown head gasket as a source of the problem? Would I see any other noticeable symptoms to confirm it's a head gasket before I take apart the head?
Thanks,
John
Thanks,
John
