mountainrancher
My nearby dealer has a KX040 sitting on the lot. I'm thinking about picking it up because I want to get started on some work despite my reservations at this time in the economy.
Chatting with the dealer, he got me thinking if I shouldn't wait for a KX057, which is a bigger machine for about $13k more. I need to do some demo and digging work that I can't do with a skid steer.
Can anyone give advice that's had experience with these 2 machines, or similar size machines, and the pros and cons. I've got a 14k dump trailer currently and would be moving the mini ex between 2 properties once in a while that are about 8 miles apart with a 3/4 ton. I accidentally overloaded the trailer to 21k pounds once while I was still figuring out weights and made the trip, so I'm not sure weight is the biggest concern because I can go slow on a usually vacant highway. What I'm trying to figure out is if I'm going to be regretting the smaller machine.
My uses are:
fixing some dams and putting in washed out overflows
fixing building drainage
installing culverts in creek crossings
demo of small buildings
cleaning up scrap metal (some heavy)
possibly moving some 1300-1800 lb haybales
moving pallets of feed & concrete in buildings
cleaning up logging roads with new tree growth and downed trees
digging water lines
pounding drill stem on hills/sidehills where I can't get to it with a skid steer
moving big limestone rocks (2x3x3 foot)
hanging the odd deer and elk up
Both properties are large, one is about 3 miles from end to end and there's about 900 acres of forest. Given, some work I want to do will require a full size excavator, so this is more to clean up around the buildings and old logging roads that have regrowth and downed trees and take care of stuff I wouldn't be hiring someone else to do and I can't get done with a skid steer. Plus some fencing that I can't do with a skid steer because it doesn't have the reach, clearing out chokecherry trees off the side of roads cut into steep hills, stuff like that. I'm currently sharing my skid steer with a business partner, but it's going to be mostly at his property and he's a PITA to deal with about it, so though I have access I'm trying not to use it much.
My uses are:
digging water lines
