Kubota v1505 overheating
Simon C
Heavy Equipment Mechanic
The motor was bastardized before me, so any part may not be original or was tampered with. It had all this issues prior to any machine shop work
Have seen some crazy hard to figure out problems in the past. Some would never have been figured out without some previous experience. Seen an engine block with 2 coolant holes for water to go from block to head that were 1/4 inch from drilled completely through. Had been overheating and destroying cylinders, never had another overheat problem.
Had to look close with head off to see, not saying it is your problem, hope you find it.
Simon C
MrFritsch
Wisconsin
I think I solved my excavator overheating. I only adjusted the “hp smoke screw” last year thinking that was the only adjustment besides high and low idle speed but apparently the “idle limit spring” which is a screw controls max fuel input for the IP. It’s under a tamper proof cap, same as the smoke screw. Both were marred up but when I read about it over summer I figured it idled fine so it doesn’t need adjustment, so I’ll just turn down the smoke screw. So yesterday I turned the idle limit spring screw in about 4 turns, a little at a time. I tracked around for an hour and used all the functions. Got it to 180 degrees and just under 200 after the hour of tracking back and forth non stop, take a 2 minute break and it cools to 180. Factory temp gauge is in the middle, a little higher when it was at 200 but not at the red. Given it’s 15 degrees outside but tracking back and forth for an hour she was as hot as I think it’ll get. No more haze under load, no power loss either. The screw must have been screwed way out for extra power, apparently that’s a hot rod thing to do besides the smoke screw. Kubota doesn’t give factory limits for the adjustments so it’s a trial and error. Last week when I drove it into the shop I let it warm up for 10 minutes and tracked to the shop and it got to 230 in the 2 minute drive.
Everything in the entire system was rebuilt or replaced. Except for the Injection pump which will be here in a few days. I tried this last minute before install the IP.
Simon C
If you ever get time to snap a picture of the back end of pump and post it I am sure many would like to see.
Simon C
