Travis Lohnes
Long time forum reader for knowledge and advice, newbie member. I have a Kubota Kx121-3 that has no hydraulic movement. The pilot pump is supplying pressure to valve block and I also have change valve pressure with safety lever down. Looking at the schematic I then checked pressure at bottom of valve bank of Pps and Pls and do not have any pressure at all. I can try to figure out how to post a schematic if anyone would like to have a look. I'm hoping for some advice before I take the machine somewhere to be diagnosed. If I don't have any pressure I assume either pump or unload valve or maybe a control valve is just dumping flow to tank.
FYI my uncle was last owner of this machine and this has happened a few times before I bought it but the problem has always just went away. It's been sitting for a while at my father in laws, went to float it home, started right up, got on trailer fine then when I got home to remove from trailer nothing would work... thanks for any input...
