L150H Volvo loader
Ben Witter
On the outside
MO2501 generally signifies the turbocharger and FMI is an abnormal update rate. This may be a communication issue with the VGT but you should have an ISO code, a letter followed by 6 digits. The old SAE code format is not used on the H series loaders. The proper code would help clarify the issue.
Also if the code is active you will not be able to perform a regen either moving or parked.
