LaPlant Choate scraper hydraulic pressure questions
ChrisUK
England
Hello all, have managed to acquire a LaPlant Choate single axle scraper as shown in picture
Needs some work before use but seems all there.
The hydraulic ram that operates the scraper is of quite a size, is this because hydraulics were at a lower pressure back in the day ?
My thinking is if the pressure was lower it would need a larger surface area (hence large diameter ram) to produce the necessary force ?
Would anyone know what pressure these were meant to be operated at ?
Also would anyone know what colour it would have been as I have only got black and white pictures.
Will eventually be going behind my D7 3T
Thanks for the help
Chris A3D3548B-902B-4FDF-83CA-FC4852BC0256.jpegD77D283A-8B4A-455A-A1BE-0DB58FA24506.jpeg
Tones
Ubique
A quick look at other scrapers from the same manufacturer the same paint as the tractor would be good.
Deere500a
Castro Valley ca
I remember on Cat a Laplant hydraulic pump was low gpm & psi 500 & later Cats 44 pump was a 1000psi but Google not finding info . Paint to match fleet in pic Allis orange,IH red or Hi way yellow
ChrisUK
England
Would anyone have knowledge of the different wheel hub sizes from American manufacturers ?
The ones on the scraper are a 10 stud fitment but the hub size is 8” as far as I can measure ( will get the wheel off next week )
We can’t find anything over here to match up with ( original wheels are fair rotted out )
Thanks
Chris
oldtom
diesel equipment maintenancesuperviser
Thanks
Chris
View attachment 361289View attachment 361290
is it the rim ,or the centre that rusted out if the centre hub ,can make a new one out of steel plate
Tones
Ubique
Would old truck rims work, TK Bedford's used a 10 stud rim on the later versions, don't know what the dimensions were though. If the stud pattern is the same the centre hole becomes an easy fix if it's different.
