Had a quick question about mounting a laser receiver on a dozer...
Currently i just welded a 1 1/2" drive coupling to the outside corner pocket on my D6R's blade and screwed in the pipe that held the reciever. This met my hopes of being simple and removable for when i didnt want the rod mounted to the blade. Also the drive coupling was out of the action and not likely to get bent/damaged.
The issue came that with enough vibration the weakest part of the pipe was the threads and eventually they gave out.
Has anybody seen a simple, easy, stout, removable way of mounting a recieving rod to dozer that they've been happy with?
someone around here is smarter than me trying to reinvent the wheel...
thanks in advance.
thanks in advance.
