jhark123
Hi All,
I have Royer soil screener that I would like to add some type of auto lubrication to. There are a lot of grease points in difficult areas and it's a dusty environment by the nature of the task. There are four belts running at vastly different rpms with four greased bearings each.
My options range from simply running lines to manifolds to make access easier to a single pump auto setup (would need to be hydraulic preferably or 12v). I could also get single point 12v/battery systems.
Anyone with experience on this? Can you put a manifold on the single point systems and use one per belt?
Thanks,
Jason
Thanks,
Jason
