stock
According to the Austrian manufacturer the shovel is designed for high volume work,with the machine being aimed at the quarry and construction sectors.
Powered by a john deere 143hp engine the L538 is a hydrostatic machine,fitted with two limited diff locks to provide 45% locking on both axles.The hydro -drive Liebherr claim to be the main difference from their opposition.Bolted to the engine the dedicated load sencing pump transmission pump provides oil to two hydrostatis motors on the rear axle.At low speeds these drive units work together to provide maximum pushing power with a shaft connecting each axle.As the speed increases the with a reduced load the oil flow diminishes to one motor to maintain engine revs at this faster pace.The hydrostatic system requires the operator to reduce the engine revs as the engine load increases.
This approach allows the swash plate angle to open up which allows more oil to the motors giving greater torque and power and has a turning circle of 5.9m .Engine fan speed is temperature regulated to help reduce the power drag on the engine this fan is also reversible to allow debris to be blown out of the rad
Engine four cyl 4.5L turbo John Deere
Power 143hp
transmission stepless hydrostatic ,40kph
Hydraulics 140L/min
Lift hight 3.7m
Lift capacity 7.2ton (metric)
Cost approx (EIRE) usd 163,000
