limb saw
gwhammy
missouri
looking at these which one is best, chain saw or circular saw for a limb saw? I'm leaning toward a circular thinking it wouldn't get pinched or torn up as easy as a chain saw. Probably going to put it on the quick attach on the mid size excavator for more reach. I have quick couplings on the thumb and my machine has a two way and jackhammer one way hydraulics which may flow to much.
Interesting. What mid-size excavator saw attachments are you looking at?
gwhammy
missouri
Don't really know, just started looking at them. Might build my own. Looks like most are a low flow, it shows my machine has 41 gpm pump but not sure what the flow is on the aux. It runs a jackhammer real good but in the two way flow it's not real fast on the thumb.
Tones
Ubique
If this is the type of work you're looking at then this type of head would be perfect.
gwhammy
missouri
Ya, that machine cost more than all my equipment combined. I'm looking at clearing edges on my farm and some neighbors farms. Just fill in work when I'm tired of doing dirt work. I've got a fairly nice tree sheer with rotating head been thinking about mounting it on the excavator but it would have to be right on the quick attach which would limit reach.
Those are impressive. Several tree companies here have one but like OP said they are expensive.
From GW's post I was envisioning something like a 3' diameter circular saw blade on the end of an excavator. :D
gwhammy
missouri
I was thinking 2 foot dia. that's the size the amish around me use on there saws to cut down trees since they can't use chain saws. That would cut about any limb hanging out. I've got a homemade brush hog I don't use anymore thinking about using the gear box and motor off of it. That would give me a good mounting point for the blade and save a lot of fab work.
Tones
Ubique
I wasn't so much post about the machine although if I was younger I could make a decent living with one. The beauty of that type of head is that you're not dropping limbs but lowering them. This type of head is made for excavators of different sizes.
Asplundh has a couple of these around here they use to trim power lines along roadways.
They came down our street the other day with one a couple of weeks ago. They used this along the ROW where no houses were and used bucket trucks and saws around the houses. I got a few trees cut down and trimmed up that I've been wanting gone for a while.
