heymccall
So, I've got an NDJ 325FLCR with a loud knock, clunk, when the stick swings back over center. Far more pronounced when bucket is loaded.
I want to shim the barrel end of the stick cylinder 80mm pin.
I believe as the stick cylinder goes from tension to compression, it is jumping from adjacent ear to opposite ear, as it has 3/16" clearance there.
Cat parts is down at the moment, but, using the pdf below, I found listings for 80mm shims.
093-0083 @ 1mm
133-2425 @ .5mm
093-0115 @ 2mm
Any way to determine if they are metal or urethane (plastic)?
Also, I saw this...
How would you go about determining if that has occurred?
093-0083 @ 1mm
133-2425 @ .5mm
093-0115 @ 2mm
Also, I saw this...
