Ok, gimme ideas.
Yesterday I got a call from the operator using the 50 ton AT Grove. He had all the main out, the job, and slider pulled, 170' tip hieght basucally. He'd picked a small part with a weight of about 1,200 pounds. the LMI showed he had 3,500 pounds, although it was still within it's rating. He had a boom angle of 74 degrees. He got off the rig to assist the riggers. Whenever he got back in the cab, the angle sensor showed him at 79 degrees, and 6,500 pounds, both out of it's rated weight and range. The Grove has a maximum of 78 degrees. He boomed down to about 65 degrees and got the alarms to go off (after setting the 1200 pound load down of course). He called me about what to do.
I recommended he draw the boom all the way in and lay it down horizontal, then kill the engine for a few minutes. He did, waited a bit, and tried again. Same thing. It had gone crazy. We tried calling a couple of people, but most were closed for the day. One guy said it had to be the degree indicator or a circuit board. I was thinking it could be any number of things.
Anywho...We went back to the job this morning, cranked it up, and it's now running fine.
So...do you dig into it or wait till it goes brain dead again? Will it go brain dead during a critcal lift?
