Does anybody have experience using this method of crack repair?
I have a crack in the block of one of our 4MG B models. It is about 4" long and at the back of the block, ending through the flange where the retarder mounts. It is not growing, but it is leaking oil beyond what is tolerable. I can get to it if I remove the oil filter and housing, as well as the exhaust down pipe from the turbo. With this system one drills completely through the block, so I would probably need to drop the pan to get any shavings out, which is a bit more of a chore with the retarder lines, but not too bad. I don’t believe it is in an oil galley.
I will check with Cat in Pocatello tomorrow to see if they have the necessary kit. Cat does have a procedure for this repair, so if they are willing I will probably have them do it, but I had never heard of it prior to talking to the Cat branch manager in Idaho Falls today. He gas not done it himself and recommended Pocatello or perhaps Meridian stores.
Anyway, I was curious if any of you have thoughts as to whether this can be done without pulling the engine, and I am interested in opinions. I would provide photos, but I cannot show the crack without removing the oil filter.
