whf4
I posted quite a bit back about at looking at used TLBs. So I finally got free from work and looked at a 1970s 580CK today. (like a ninny I didn't check the plate for the date and exact model number). 50-60 hours on rebuilt engine after a catastrophic failure, all 50-60 put on by the present owner who bought it after the rebuild.
The good news: the 4 cyl diesel started first touch of the key in about 42 degree weather and I do not think the owner had been warming it. No smoke even at startup.
The shuttle shift seemed to work fine, tho I have not operated one before... We were in a small yard and the brakes seemed uncertain to me so I did not exercise the transmission beyond forward and reverse in low gear.
I put the loader and the boom of the hoe out horizontal, killed the engine, and went on chatting with the owner and check the engine oil. Looked dark but fine to me; maybe a faint whiff of diesel odor but put some drops on a paper towel and waited, no halo. I think its just oil, not contaminated with diesel.
The boom and the bucket had not budged at all while I looked at the engine. Doh! forgot to look at the coolant.
I put the loader bucket down and up and picked the front wheels off the ground several times. I did not detect any change in the relationship between the front wheels and the axles. The loader operated smoothly through its range of motion (booms and bucket) as did the backhoe and the stabilizers.
The rubber looks great.
Now the bad news.
Big: the pin/bushings where the hoe connects to the main body of the tlb has way more play than it ought- probably 3/16 wiggle when you put the hoe into the earth so that it goes from pushing up to pushing down. Similarly witht he hydraulic cylinders that move the boom from side to side. There was visible play where the cylinder rods attach to the boom (maybe not the right word) of the hoe.
The brakes are imaginary, if the two pedals on the right above the throttle pedal are in fact supposed to be brakes. The pedal on the left side of the tlb stops forward motion when pressed. I am not trying to be snotty, they looked like brake pedals to me, but nothing happened when I pushed 'em.
Small(er) stuff: leak at fitting between hose and cylinder on how boom extension. Owner states adds hydraulic fluid, a gallon every "so often". He had pretty clearly filled it and acknowledged overfilling ti as a fair amount of hydraulic fluid escaped through the ports on the tops of the loader towers and dribbled down.
Tractor does not charge; owner hooks battery to a charger every few weeks.
ask is $5500 firm.
What I want it for is to dig footers for a garage, drain tiles around my house, MAYBE expand a pond (tho I have certainly seen warnings posted here about the uninitiated who try to dig ponds). I will at some point need to trench 800 feet of water line in form the curb. I am reasonably confident I can address the leaking fitting and the charging issue on my own. The backhoe attachment point - no way. The brakes- I'd need to learn more about what is involved before attmepting it on my own.
For what I want it for, how urgent is addressing the slop where the boom of the hoe attaches to the tractor body, and the slop in the cylinder rods that swing the hoe?
How big a deal is fixing the rear brakes? I have done tons of brakes on CARS but not on a machine like this.
thanks in advance for your patience and your help.
Bill
Now the bad news.
ask is $5500 firm.
Bill
