Legdoc
So it's like this. Over the weekend I was was discing a winter pasture for livestock with my Kubota M9540 tractor. The left lift assist hydraulic cylinder blew out. I was able to complete the job by making wide turns in the loam field. I had to leave the implement in the field as the machine would not lift it. We lost some fluid in the field and none showed on the dip stick. I decided rather than just topping off the system we should drain what was left and go for a refill with new OEM filters and fluid which we did.
On installing each $50.00 filter I noticed "made in China" well that pissed me off! Well lo and behold, after an exhaustive nation wide search this morning Kubota has discontinued all seal kits and cylinder parts offering new cylinders only at just short of $1,000.00 each. I believe this corporate tactic is outrageous and just another attempt to victimize the consumer through greed. So here is where I'm at.
1. Try to find the seals elsewhere. Hercules?
2. Going forward with filters find another source possibly Donaldson?
All of this BS takes up precious time!
Anyone else feel the same as I do? Or am I just getting old and remember the way it used to be and not wanting to roll over and be a victim?
