Columbo
Hi all, my front lower roller (directly behind the idler) has decided to pack it in. I’ve heard that rollers shouldn’t be replaced individually, is there any truth to that? Does it matter which roller is replaced for this “rule” to apply?
Also, on the opposite side track I have a squealing noise in forward but not in reverse. The bottom rollers seem ok, all turn with some resistance, which leads me to suspect the top roller. Any other tips to diagnose this before I slack the track off and inspect the top roller?
If it matters it’s a Cat 311B, S/N 08GR00401. Thank you!
