My '77 RS600 seems to be stripping the drive hub studs for the axles. Not sure why this is happening. The Mack dealerships solution was to drill and heli-coil for fine thread bolts.
Is this a common issue?
Maybe an actual gasket (vs only silicone) between the hub and the axle shaft would give a better friction surface and bite to resist movement?
Thanks
Thanks
