Memories for us old truckers
RZucker
Wherever I end up
Mechanic/welder
Were a lot of rubber band drive tandems in the Midwest around that same time frame.
Up here in the NW too. In the early 80's my old GMC 9500 was down for a few days and I had to keep hauling grain, so I borrowed a 1970 Chevy C70 427 with a 5x2 and belt drive tag on Reyco suspension. The thing doubled my fuel bill and was real interesting to back out of the driveway... as soon as the rear axle went up the slope you were done. I learned to back a 40 footer around a 90 degree corner at 15 miles an hour in a hurry. Get a run or you weren't getting out.
RZucker
Wherever I end up
Mechanic/welder
You gotta love the big dogs. I'm seeing a 12V71 in one of those, might even be able to go turbo with a trick I have thought over many a time.
Why not use a double set of 6V turbos using 4 exhaust manifolds? Turn one to dump left and one to dump right depending on the truck setup... Steering, etc. It's just an idea I had looking at a Long hood Pete with an NA 12V71 a few years back.
There just isn't that much room because the B cab firewall isn't flat. The B73 barely accommodates the 335. The fan is right up to the radiator and the fuel lines are 1/2" off the fire wall.
Where is that rear drive air compressor going to live? Now mine with 16" added a 12V would fit. Don't get any ideas:).
kshansen
Central New York, USA
The DM series made a good looking truck too. I guess I like flat fenders and butterfly hoods.
Yes and access to engine was good with fenders flipped up.
Problem we had is hardly anyone was smart enough to notice the grease fittings on the front of the fenders. Then when you needed to work on engine they would be rusted solid. Last I knew there was a brand new left fender sitting in the store room at the quarry along with a couple of the chrome strips for the hinge.
