Memories for us old truckers
Worst dock I ever had to bump was the Old Pacific Produce downtown Vancouver BC.
The lot was a triangle shape-pull to one point then back on the blind side at a adverse
angle to dock normally between two trailers, I never had the luxury of bumping that
dock during daylight hours, always in the dark and many times pouring rain. They made
sure to put plenty of obstacles in the way-like pallet stacks.
Friend-wheat farmer Dwight bought a 1987 FLC today for $4,000. 3406 350-has a blown 10 speed.
Has a wet kit which he doesn't need, 230 WB on air ride, AC works, inside is in good condition.
For the fact he is a ex Cat dealer mechanic, he will tear the engine down and do a complete rerate
to 425 plus a little added fuel-he already has a RTLO high torque 13 speed. I ran across this
told him about it and he ran over wrote a check. Plenty good truck for hauling grain. Photo for
reference-not the truck.
stinky64
java center ny
big truck wrench/fixer of things
Typical street backing to dock in big city, did some of that.
Yuuch., mostly on back hauls, mostly to downtown Buffalo bumping a dock that was built in the 20"s or 30"s for 28 ft. trailers with a 53 and large car Pete, sometimes got lucky enough to have a 48. aahh good times. My Pops was a city driver for 40+ years and when I would tell where I'd delivered he would just bust out laughing, "you're the one who wanted to be a driver dumba$$"
@Truck Shop I found a picture of a similar Lorain truck crane that I worked on and around in 1980.
The one we had was equipped with an Atlas ( I think ) gas engine in the lower, an 830 cube inline 6 that made 250 HP. It was a 1960 and I can't find anything on that engine. I remember it had a huge carb on it. It was a Moto 545 with the banana outriggers like this, dual steer axles, etc.
Any idea who made that carrier?
It had an air shift 5 speed and a 3 speed brownie.
We took the counterweight off by lowering it down onto rails behind the cab, on little rollers. Push it away and swing around , and load it onto a truck. Often it was sent away in a tandem dump truck.
yes it sucked for the bridge rule I would bet. With the CW off it was 80,000, and was 10' wide with the outrigger boxes on. Those are the old banana out and downs that were a bastige to set dunnage under.
In those years plus cranes being considered industrial-powered, my best guess would be
either Waukesha or Continental both built large cu. in. gas and diesel for custom industrial
equipment. & cranes are kind of custom. My best guess.
Old Doug
Mo
Does anyone know if they made Stainless Steel door hinges for this model and if they did were i could get some?
RocketScott
Lexington, KY
Somebody killed my scale shack where I figured out the 120 position on the tilt trailer. I found out later it was never closer than about 500 pounds to reality at best.
That's been gone for a while hasn't it? Last time I drove past that was around 10 years ago when I was building a house off 304th
