What is the weight on a D7F? I've been searching around the web and can't nail down a weight of one. I've seen all the way from 38000 to 54000lbs. I've got a tandem axle detach and I'm thinking it's not enough trailer. Also where is a good spot to look up serial numbers?
There are many factors I would consider before acquiring a 7F. Specifically, what do you need it to do for you. I operate 2 D7F's, for the government, they are solid machines but tend to overheat if pushed really hard here in the southern states. Most of the F's on gov inventory have sat for months if not years and the hour meters typically don't tell the whole story since it only counts a true minute at 1500 rpm. 300 hrs is really typical, I inframed ours when it had 500 hrs on the original meter. That was in '05, it now reads 310 hrs. There are 2 different engines often found in these dozers, one is a more updated version and lacks the power of the older engine. Both scale a few hundred pounds over 50K. Both are '73-'74 models. If interested I have full parts, service and operators manuals in pdf plus the winch manual. I can give a lot more info on this particular machine if you'd like from both an operating standpoint as well as maintenance.
Sometimes it's easy to be tempted by the bid price. thinking I'm better off for passing up that unit. maybe if it was a little closer, .........say down in IA or something I'd be more interested, but as it was said earlier the ones in IA are tending to sell high. I'm thinking the 7's were maybe an in between size that I may or may not be happy with anyway. There's a guy not to far from me that's got a 73'vintage D8 civi cat that is priced right with no pressure to buy either. new rails, new sprockets, etc etc.... he's even said I could rent it first to see if I like it. bad thing is there is no ripper, and I really could use a ripper for tree roots and etc. As for plans for buying military.................we'll see, not loosing any sleep over the ones that got away.
