Hey,
I have a 1.5t mini digger, and having trouble with the dozer blade.
The mini digger cant lift itself with using only the blade. If i lift the excavator with the arm and then lower the dozer blade, it stay still.
Since i now are repairing and changing parts, i want to fix this aswell.
I have changed the seals in the swivel joint, since the belt motors was weak under load/resistance. Belt motors are now working fine, but dozer blade having the same issue.
Then i sent the dozer blade cylinder to get new seals and o-rings. They pressure tested it before and after, and before it had a minor leak between the chambers. After the seal change it was pressure-tight.
Still won't lift itself.
So i wonder if small diggers cant lift itself with the dozer blade? The diameter on the cylinder is the same as all other cylinders.
Any other tips what can be the problem? What to check next etc.?
In advance, sorry for my english, its not my native language.
