Hendrik
Like I said, your regulation are different to ours,for one thing it is illegal to use a lift point that is attached to a bucket. Must be attached to the dipper arm, linkages or quick hitch and must be certified to be for that particular size of machine. There is a risk that the lift point can tear out of the bucket.Where is safety regulations being broke at? 1 Nothing wrong with the mini being lifted out of the hole this way.2 The excavation was designed and stamped by a professional engineer.3 slopes are 2 1/2 to 1 and at the bottom 12 feet are on a 1 to 1 slope. No offense but I excavate for lift stations daily and this one is not considered deep in my line of work,OSHA visited me on this project and the only thing I got wrote up for were a couple of drop cords.Tell me whats wrong in these pictures.
The ground looks reasonably stable in the bobcat lift and you are back from the edge but I would like to say that in that sort of situation there is a chance that the ground can collapse as the weight of the mini ex puts more weight on the front of the SK480, by the sounds of it you are an experienced operator and know the dangers involved and would have assessed the ground conditions. However in the interest of safety I want to point out that ground conditions can change if there is water involved, for example if there is a layer of clay that has gotten some moisture in it, that can slide/shear.
In the transformer (I assume) lift the ground crew is too close to the lift and should be using a tag line to manoeuvre the transformer into position, if for some reason that load drops, they may well get crushed. Sure once the load is within a couple of inches and it has to be dropped onto bolts, then you need to get closer.
Not sure whether a bandana is a approved safety helmet and over here they would be required to wear high vis stuff, well everyone on site would have to, there would be a sign at the site entrance that shows the required PPE (personal protection equipment).
Also that fella watching the dozer work is not wearing a hard hat, so if something falls off the top of that pumping station, he is going to have a big headache.
Don't know the weight of the transformer but the SWL of the SK480 is round about 6-10 tonnes at that lift location, however in the picture where the SK is not level the SWL will be affected and having the load at an angle to the machine will put strain on the slew motor and as the ex tips over the hump it may well cause the load to swing. Sure that may be the only way to have done it but it is not ideal.
Another thing is that over here only a qualified dogman/rigger is allowed to attach a load to an lifting device, the only exception is a repetitive lift where a dogman has calculated the load. However the excavator operator also needs to know that the dogman has done his/her job properly because the operator is responsible for any load he/she lifts and moves.
For example lets say that transformer weighs 4 tonnes, what should be the load rating for each of those straps?
Look I am not picking on you but pointing out that we have stricter safety regulations and also making those with limited experience aware that lifting loads with excavators is a high risk activity.
For example, someone sees your lift point on the back of the bucket and decides they need that too, not realising that may be illegal and/or dangerous. You may well have got your lift point bucket professionally made and certified but someone who grabs a bit of scrap steel (of unknown strength), drills a hole in it and welds it onto his/her bucket, may well be setting themselves up for disaster.
