fest777
i noticed that when i broke down the jaw cylinders that there is no wear sleeve in the head of cylinder, just below the packing its solid steel, i have noticed that there is a type 2 kit that has a 2" ring or sleeve made of the same material that is on the piston the band with the angle slice in it, now it that an upgrade or just a different type head, iam a also a journey machinist and can see that a blind bore could be done and accept sleeve, is it worth doing this or should i just leave it be ? i do not like the cast iron on rod scenario but thats the way it was when torn down, what kind of clearance is allowable, 1 is too tight had to tap it off sledge hammer other was real loose and both are galled thanks anthony 955 85j07794
