I finished up the service in time to run down my pit road a few times before the rain. Amazing how nice of job it did I never want to do a road again with a dozer. I will have a learning curve. This is my first time in a seat.
I thought the hoe had grease fittings. I found a wire off the rear ripper. That was a nice easy fix. the Rotary valve needs to be resealed. The seal around the parking break pinion going to the disk is leaking. parking break disk. Still need to repack a lift cylinder. Anyway after a good steam cleaning I still fell real good about my purchase. I am sure after next summer I will be looking to install Red Dot AC.
It may be older but with low hours everything is still real tight from the doors to the front end. With problems the newer class A trucks are having with the emission equipment. I Don't have a good feeling going forward with all the used tier 4 used stuff hitting the market.
gov liquidation and gov plant are both re-marketers of used Government property. I wanted a smaller one like a Deere 570 that I could haul on my Tag. I couldn't pass this up.
