What is the STC? And why does it only do it in 9th? In 8th it will go to high idle.
The N-14 mechanical was the first of the N-14's and was built in later 91 thru early 93. It was for all intent and purpose a good engine.
STC means Step Timing Control it controls injector timing to minimize white smoke on start up. It has two stages of timing [advanced
during cold starts and normal timing for engine load requirements. The injector timing is controlled by engine oil pressure to the STC
valve located on the left rear midway up the block. The only hoses going to the STC valve is #1 a fuel pressure hose #2 oil outlet line.
#3 oil feed line.
Remove the fuel line from the bottom of the control valve and check to see if there is engine oil mixed with the fuel. It should be clear
diesel at that port. If not the STC valve has an internal leak and is replaced as a unit.
Do you notice the injectors change pitch? The STC valve has a low and high shift point- when you hear the injectors go from a clatter to
quite that is the shift from advanced to normal timing. This injection system can be complicated to explain, but in theory it is fairly
simple. I really suggest buying the Cummins manual it covers STC and the Celect and Celect Plus engines.
