Need help finding engine rebuild kit for D6C 3306
Mike Knight
Southern Oklahoma, USA
Hello all, I am needing some help trying to find a engine overhaul kit for our Cat D6C dozer. I have contacted the Cat dealership to get a platinum overhaul kit but found out that they no longer offer them for this specific engine arrangement. I'm kind of hoping that maybe someone has one stashed away (wishful thinking, I know). It is a late 1960's dozer not sure of the exact year. Serial number is 10K9870. Engine model 3306 serial #3N17402 and the arrangement # 2P6795. I have not had much luck finding a complete kit on the internet. Would someone possibly know if another engine kit would fit from a different piece of equipment? Cat offers platinum kits still for newer equipment. I found one kit for a D6H dozer part# 20R-1482. Would it possibly be compatible? Thank you in advance!
Coaldust
North of the 60
I’ve always pieced them out. I doubt there was ever a “kit” available for that engine. Most dealers have a “standard jobs” list of every part commonly ordered for such a job. You could ask the service dept. The wild card will be the crank. But, your mileage will vary.
Chrisso
Diesel Mechanic
From what I can see, the best you're going to get are gasket/seal kits, there's plenty of them.
The problem with the 20R-1482 Platinum kit is that it's not listed as compatible with your machine s/n. The time an effort you go to trying to figure out why would be better spent piecing the parts out as suggested above.
Mike Knight
Thank you for the info Coaldust, I could have swore that I had found a kit that was compatible with that engine but that has been a few years ago when we knew we were going to need to overhaul it. I very well could have been mistaken at that time. We'll give cat a call back and hopefully they will have a common parts list.
Mike Knight
I have a pretty good feeling you are right, thanks Chrisso
Check Break
USA
Give IPD a call. They offer a lot of what you need for a 3306. https://www.ipdparts.com/download/ipd-parts-for-caterpillar-3304-3306-engines-english?wpdmdl=806
IPD is high quality parts. They make 3 ring pistons for 3200 series engines that Cat doesn't offer. They are an improvement over Cat 2 ring pistons. The shop that did my engine uses a lot of IPD parts in their rebuilds.
Mcrafty1
Central Maine
Earth work
https://www.reliancepowerparts.com
They list many parts for many machines/engines The 3306 being just one. I can't vouch for their Cat replacement parts but I rebuilt my Mack E6 several years ago with their parts and it's still going strong today.
My bad, I have too many different brands of diesels...lol, PAI was where I got my Mack engine parts...But Reliance does list CAT engine parts, maybe they can help you.
