justafarmer
Got a good deal on a rake, problem is its for a CAT330 and im hoping to use it on a Hitachi 230 which is 90 mm with a pin grabber q/c. The top pin of the rake is 90 mm so that is fine but the bottom pin is 80 mm. The other problem is that the Cat distance between the pins is about 21" and the Hitachi is 18.7". I know this is sounding pretty bush league to many of you, but it is for farm use maybe a week or two a year. Any tips or advice would be appreciated. Attached is the picture of the rake with the CAT set-up. My initial thoughts are to cut out the 80 mm bushing and then cut the new 90 mm hole where its supposed to be then weld in a new bushing. Looks like the new pin will go towards the top of the existing 80 mm hole. Thanks.
