My skidsteer developed a knock which seemed to be coming from the front of the head, it also ran poorly and had low power. I adjusted the valves and didn't find much adjustment required but the knock seemed to go away although I was not able to put under load. Finally got to put under load and the knock came back. I thought sure it was a valve problem so I pulled the head and the valves appear fine, although I haven't disassembled the head. The only thing that seems odd is that the front cylinder has very little soot on the head wheras the other cylinders have a slight layer of soot across the head and valves, the difference is very noticeable. The machine runs good enough that I think it's a least running on 3 cylinders, so I suspect a problem with the front cylinder.
So now I'm thinking a fuel issue or maybe cam/lifter issue.
1. Does this line of thinking make sense?
2. Is a knocking consistent with a cylinder not firing?
3. Is a knocking consistent with a pump problem?
4. Does this engine have lifters... hydraulic/mechanical (pushrods look good)?
5. Is knocking consistent with cam/lifter problem?
6. Am I even on the right track?
