New from Volvo.
cps
Ireland
plant mechanic
Any one here seen or heard anything about these machines? found it on the net, and did nt know they were making one!
9420pullpan
Central PA
when you have those pull type scrapers you need all of the weight on the front axle. on my old 9420 there was nearly 6000lbs in wheel weights and suitcase weights.
John C.
It looks like and artic truck front end with a custom rear. I'm thinking that puts a huge stress on the center bearing.
Why not just us an artic with a hookup and hydraulics to run that mess. Put some weight in the box and then have four driving wheels in the rear.
JimBruce42
Pennsylvania
operator
Like pullpan said, when those pull type scrapers dig in, they really pull down on the drawbar and rear end of the tractor and lift the front up, so you want as much weight as possible in the front. As far as just hooking it to a tandem rear axled artic, that would be hard on the tires, you typically want to turn a loaded ADT as little as possible because of the strain it puts on the tires.
I personally wonder how good the view is of the front bowl on these Volvo's, there's a lot of tractor from the cab to that first bowl. :beatsme
Richardjw~
South Devon, U.K.
yes, the ideal weight split for an artic seems to be about 65/35 in favour of the front
the only thing I would say is that the STX/JD artic set up were designed from the outset to pull.....whereas this machine 'appears' to be a dump truck with the butt took off (correct me if I'm wrong) which was designed for carrying.
Richardjw~
South Devon, U.K.
in the instance of the STX you will find that actually the draw bar is attached to the from half making it even more efficient because it pulls down the whole machine - as well as sharing the load and not using the pivot joints to transmit all the draft
Look at some of the other brands out there pulling only from the back end (rear section) and they look like a tired old hound dragging his ass along the ground
hvy 1ton
Lawrence, KS
Looks like volvo going after the bell scraper tractor market. The volvo has a noticeably longer wheel base than the bell tractors. I wonder what the pros/cons are besides the obvious. I didn't think it was a very big market, but i guess Volvo thinks otherwise.
hoeman600
PA
yellow thingy moverer
Volvo had this truck at con-expo in 05 so its nothing new . Im sure they tested the hell out of it. And if its anything like their trucks it will be a very good machine!
Richardjw~
South Devon, U.K.
when you put the human perspective in there it looks a whole lot bigger
maybe also going in to the cane haulage business???
Dualie
Nor Cal
Might as well put a service body on the back to fix it when it breaks.
don't see this working very well for Volvo but thats my own opinion
hiballer627
Alberta
We had a scraper pan hooked to a 30 ton Moxie ADT on a demo at our site last year. I didn't run it but it looked pretty lacking in the traction department, even with all diffs locked up. Worked good in the topsoil, but throw some wet dirt at it and it sat there spinning. Good speed on the haul road, but slow climbing the pile. Maybe a good unit for stripping jobs where its dry.
