LCA078
Skyking is pointing out some very key details that can make your life much more happier.Not that Doosan.
Example machine:
https://seattle.craigslist.org/see/hvo/d/everett-2006-hitachi-zx-200lc-excavator/7824336889.html
1) This is an Hitachi which I think is similar or practically same as a John Deere. I think they share a lot of parts but I'm a Cat guy. Hitachi/JD guys can chime in and discuss the benefits of those brands but I know each is highly respected.
2) This machine has a beefy progressive thumb which is about the best you can find. A fixed thumb like on the Doosan you posted is okay for basic grabbing but it's limited on diameter of what you're grabbing as you have to curl the bucket a lot more to grab smaller items. And that can get in the way a lot of times. A simple hydraulic thumb is better (what I have) but you can still limit out on what you can grab as these thumbs have limited range of motion, like I can't go past center. And the grip capability decreases the further you extend the thumb. On the other hand, a progressive thumb like the one Skyking shows gives the most constant range of grip along with the largest range of motion. Again, the type of thumb is a small detail but it makes a huge difference in machine capability when a lot of picking/placing will be done with a hoe.
This machine's progressive thumb:
My machine's thumb. And if I remember correctly, I took that pic with my thumb fully extended. A progressive thumb will curl the thumb a lot further, past center and a bit more.
