USA/Canada Home Worldwide Sites Our Company Contact Us Site Search
Construction & Forestry
Home Products & Equipment Services & Support Parts Finance Solutions Where to Buy Info Center
Construction>Excavators>0 - 6 Metric Tons>50C ZTS>Specifications
Construction
Excavators
0 - 6 Metric Tons
50C ZTS
Features
Specifications
Compare
Build Your Own
Forestry
Used Equipment
Non-Current Model Specifications
Rental Sales
Federal & Military
50C COMPACT EXC.
Specs
MANUFACTURER John Deere
MODEL 50C COMPACT EXC.
DATE OF SPECIFICATION Nov-03
ENGINE
Manufacturer/Model Isuzu / 4LE2
Net Power hp (kW) @ Rated rpm 41.5 (31) @ 2200
#Cylinders and Displacement cu in. (L) 4 - 133 (2.2)
HYDRAULIC SYSTEM
Main Pumps, Type Piston
Total Main Pump Flow gpm (L/m) 29.1 (110)
Normal Relief Pressure psi (kPa) Not published
Auxiliary Hyd. Max Flow Rate gpm (L/m) 22.5
Lever Pattern Change Std
UNDERCARRIAGE
Track type - Std / Opt Rubber belt / Steel shoe optional
Track Length on ground ft (mm) 6' 5" (1 960)
Ground Clearance in. (mm) 13.2" ( 335)
Standard Track Width in (mm) 16" (410)
Ground Pressure, Std. Track psi (kPa) 3.80 (26.2)
Max. Travel Speed mph (kph) 2.7 (4.3)
Gradeability % - (deg) Not published
Max. Drawbr Pull lb (kg) Not published
BUCKET
Std. Bucket Width in. (mm) Not published
Bucket Size SAE cu ft (cu m) 2.1 - 8.3 (0.06 - 0.24)
BLADE
Blade Width ft (mm) 6' 6.7" (2 000)
Blade Height in. (mm) 15.2" (386)
Blade Max Lift Above Grd. Level in. (mm) 16" (406)
Blade Max Lift Below Grd. Level in. (mm) 14" (356)
PERFORMANCE
Standard Arm ft (mm) 4' 5" (1 350)
Max. Digging Height ft (mm) 18' 6" (5 640)
Max. Digging Depth ft (mm) 11' 10" (3 610)
Max. Digging Reach ft (mm) 19' 0" (5 790)
Max. Digging Reach @ G.L. ft (mm) Not published
Max. Dump Height ft (mm) 12' 11" (3 940)
Max. Vertical Digging Depth ft (mm) Not published
Min. Front Swing Radius ft (mm) 6' 11" (2 110)
Min Frt Swing Radius w/Boom Swing ft (mm Not published
Boom Swing Angle degrees L/R 60º / 80º
Lift Cap. Over Front @ 10' G.L. lb (kg) 5,190 (2 354)
Lift Cap. Over Side @ 10' G.L. lb (kg) 2,151 ( 976)
Arm Force - Std. Arm lb (kg) 5,512 (24.5)
Bucket Digging Force lb (kg) 8,378 (37.3)
Tail Swing Radius ft (mm) 3' 3.4" (1 000)
Tail Overhang over Side of Track in. (mm 0.0
Swing Speed rpm 9.0
TRANSPORT SPECIFICATIONS
Std. Transport Length ft (mm) 17' 5" (5 310)
Std. Transport Height ft (mm) 8' 6.7" (2 610)
Std. Transport Width ft (mm) 6' 6.7" (2 000)
CAPACITIES
Fuel Tank gal (L) 13.2 (50)
Hydraulic Reservoir gal (L) 12 (44.7)
SAE OPERATING WEIGHT lb (kg) 10,252 (4 650)
Metric Ton Weight 4.65
Specifications subject to change. Please contact your local dealer for more detailed information.
Copyright © 1996-2004 Deere & Company. All Rights Reserved. About Our Site | Privacy | Legal
