dozerin
Hbxg dozer functions like hydraulic dozers through their feature of pilot joystick hydraulic control and hydraulic direct drive motors. These advanced and latest technology hydraulic dozers equipped with elevated sprocket and Cummins engine for better performance than the other dozer models falling in range. Hbxg Company model Sd6n, Sd7n and S68n.
More powerful engines, better tracks, more reliable drive tracks, raised cabins and instead of the usual cable operations, hydraulic arms were some of the important improvements included in the bulldozer development. More precise blade manipulation was made possible by hydraulic systems.
Main configuration:
Torque converter - Torque converter is power separating hydraulic-mechanic type.
Transmission - Planetary, power shift transmission with three speeds forward and three speeds reverse, speed and direction can be quickly shifted.
Steering clutch - The steering clutch is hydraulic pressed, usually separated clutch.
Braking clutch - The braking clutch is pressed by spring, separated hydraulic, meshed type.
Final drive - The final drive is two-stage planetary reduction gear mechanism, splash lubrication.
Dealership in India, With 'Daya Charan & Company'
Main configuration:
