NH575E
When I acquired my diesel generator I set up a couple of metal oil drums to store fuel in. Over a few years they started to form some surface rust inside so I switched to plastic this year. The other day I was about to fill one of my tractors and noticed a big split in the side of one of the plastic drums. Thanks goodness it didn't split below the fuel line. The other drum was empty so I just pumped the remaining fuel over to it for now.
SO I'm put out with steel and plastic my next choice was to buy an aluminum tank. I started checking around and new tanks in the 100 gallon range were $700 - $1300 and none to be found. I called a company near me that builds them and they wouldn't sell direct. On top of that the guy said they were 16 weeks and 8000 tanks behind in production.
Moving forward I called a couple of the diesel truck shops to see if they had any suggestions for buying a used saddle tank. The second place I called gave me a contact nearby that indeed had trucks they were scrapping out. I was hoping for a rectangular tank but the few that had those were steel. All the aluminum tanks were round. Most were damaged or full or had something i didn't like but I found one decent one in a pile already removed. Bought it for $160 and change with tax.
I modeled how i want to set it in the barn. I just screwed some plastic chocs to some pieces of landscape timber to form a cradle. The final resting place will be where the drums are now. The filler hole is a press fit for 2" PVC so I am going to use that to adapt my 2" NPT pickup tube for my pump. I have ordered a Goldenrod Dutton-Lainson Water Block Fuel Filter to add in front of the pump. I am also going to add a mechanical fuel level gauge.
