Maxwedgehead
I have a 2018 next gen 320 cat excavator serial HEX01610 and I'm having an issue with pump 1 staying upstroked. This happened originally in December and we put a new control valve on that pump and the issue has been gone ever since.
Originally it happened instantly in the morning at first start up. Today we were using the machine fine all morning, came back from lunch and it wouldn't even idle at normal rpm. Turned the dial up and the engine revs extremely slow and you can hear the pump is loaded just like last time. Checked the service screen and verified at idle pump 1 is around 2000psi with pump 2 at 250. At wide open throttle its 4600psi on pump 1 and 350 on pump 2. I'm having a hard time believing a control valve is bad again with in 6 months. We are going to try to swap control valves tomorrow anyways to see if it changes to the other pump. Any other ideas why it would be doing this? Could the pump itself have something internal wrong with it that would cause this? Machine has 5900 hours with nearly half of them being idle hours and wouldn't think it would have a wore out pump already.
Also checked joystick outputs in the service screen and the machine is not sending any voltages to any functions indicating its trying to stroke it on its own. Pump unplugged it stays the same pressures.
