No power on my cat skid steer
Junkyard
Claremore, OK
Field Mechanic
Battery dead? Bad battery cables? Dirty ground? Without more info it could be a lot of things. Model? Serial number?
Throw out a bone or two for a kickoff..........
As Junkyard pointed out, model & Serial Number is always a good starting point.
Then - what's it doing.? Dash does not light up when you turn the key on.? Cranks over but does not start.? Any & all info you can supply helps members here to help you.
Steve Frazier
Founder
Staff member
LaGrangeville, N.Y.
cjmac247 I see you're new here, welcome to the forums!!
If you can be more detailed in the description of what you've got going on we've got people here who can help you sort it out.
If you have no electrical power at all you may have a red main circuit breaker that's tripped, on my machine it's located at the front left of the engine compartment and you will have to hunt for it. Push the reset button until it clicks and try your key.
