Snowbird
Looking for any thoughts on what to check next.
I have a 2011 E35 with a Kubota D1803 engine. I purchased this unit used in the fall of 2022 and did the 1000 hour service and etc... Has always started on the first half a crank until a few days ago on a job. I went to start it up and started to crank but the error exclamation indicator cam on and interrupted the key start. No code just the error light. Turn key off and back on just repeats the result.
What I have done:
It was giving me the 250hr service message so I reset that.
Checked all the fluids, looked for obvious things.
I suspected the shutoff solenoid so I unplugged it and tested both the start and hold and could hear it click. So while forcing the solenoid open with the start coil and jumping the starter the engine started and ran as normal as long as I give the solenoid power.
I also disconnected the battery for a while to reset any fault in the ECU
I'm sure I can remove it from it's current lawn ornament function on the job site but would really like to get to the bottom of what fault is causing
the issue any thought would be of help
Thanks, Dan
What I have done:
Thanks, Dan
