NOPE!!!!
old-iron-habit
Moose Lake, MN
I can't find the pictures now, but there are some out there with two Cats hooked in tandem driving over the hard snow base pulling a V-plow equipped grader over one of them passes while opening it up after the winter closure. Looked like a avalanche waiting to happen to me. Crazy stuff!
hvy 1ton
Lawrence, KS
Seems like a large scale blower would be a lot safer!!!
The dozer is just to knock the top of the snow down enough for the blowers to work.
I've seen this one from yellowstone.
John C.
It's done on the road into Mt Rainier park every year plus Chinook pass. Probably the closest to those in the videos is the one to Sunrise. It's pretty common to have twenty feet of snow to push over the side before they get close to the pavement up there.
Mobiltech
Sask.
Looks like a good place for a purpose built blower . I’m thinking a 973 track loader with a 300 hp loader mounted direct drive blower. Gives you the ability to lift it up in the air and take the top off.
Maybe even better mounted on a excavator with a telescoping boom like a delimber.
I’m sure we could fab something up.
Something like this but 5 times bigger and stronger.
hvy 1ton
Lawrence, KS
Part of the problem with using blowers is some of these roads are used all winter by snowcats, snowmobiles, etc. The snow is packed so hard by spring it's difficult to feed it through a blower. I know that's why they pull the v plow with dozers in yellowstone.
cuttin edge
NB Canada
Finish grader operator
Wonder why they don't put a v on the dozer instead of pulling the grader?
I've plowed snow for over 40 years...no way in hell would I do that.....those guys don't get paid enough.
Ed
I wonder if a guy could engineer a quad 9 on rubber shoes with a wedge like that, only wider. The weight of the snow would give you traction, methinks. Maybe a progressive V that had the road section fixed and the side wings adjustable to go over guardrails. Maybe mount those side wings so they put traction on the rear unit. Signposts are gonna be toast any way you slice it.
cuttin edge
NB Canada
Saw pictures before of Dozers in Newfoundland with a V and 2 wings. My old V hasn't been on the grader in 20 plus years. Old iron habit has a post of a dozer with a V and wing I think
