tywark
Hi, I have a NPK C4C Compactor that seems to be building too much pressure and keeps wanting to blow out the shaft seal on the hydraulic motor. After I bought it (auction find) I found out the motor was leaking hydraulic oil into the exciter housing. I took it apart to replace the seal and noticed one of the metal spacer washers that help hold the seal in place had also broken when the seal went out. So I replaced the seal and put a different washer in there, I then put the motor back together, hooked all the hoses back up and ran the motor for 30 seconds and I notice the washer has bent already from internal pressure. I tried straightening it out and turning it around/ inside out and ran it again and it started bending again. Any idea what could be causing this? We have only been running it on a small MT55 Bobcat skid steer and Yanmar 4 ton mini excavator so shouldn't be building to much pressure, should we? I also took out the pressure relief valve with I believe is set at 2650 psi and took out all the other plugs that I could in the bypass relief block and nothing seemed out of the ordinary.
Thanks in advance
Thanks in advance
