hosspuller
I have a 45 degree O-Ring boss fitting that's leaking. The problem is: It's installed in a valve that is obstructed and prevents fitting removal without removing the valve. The valve is buried in the machine and is almost inaccessible. The fitting can be unscrewed about 3/4 of the thread before hitting the axle housing, so the washer and the O-ring is accessible but not changeable.
Is there any solution or trick to the leak I'm missing ?
