I was curious as to whether anyone has any experience of oil sampling (whoever the lab may be) actually providing prior warning or evidence of abnormal system condition... excluding failure related to glycol or fuel dilution in an engine.
Wulf said:I was curious as to whether anyone has any experience of oil sampling (whoever the lab may be) actually providing prior warning or evidence of abnormal system condition... excluding failure related to glycol or fuel dilution in an engine.
CGSI said:Oil sampling is just like any other tool. if you use it properly and trend the results you cam maximize the equipment use and extend major component lifetime by a great deal. IMO
Squizzy246B said:Dead right. Before starting my own business I was conducting machinery failure analysis, mainly on diesel engines. The amount of times that I saw a worrying trend in the oil sample results that nobody picked up (prior to failure) was amazing. 1 sample doesn't really tell you a lot. You need a series of tests (history) over a period so you can look at trends and even then you need some knowledge to make sense of the results. Different makes of engine have different characteristics. An oil sample taken today is not going to tell you about the coolant contamination of tomorrow. A useful tool but not the be all and end all.
Probably the best and most conclusive thing an oil sample will tell you is fuel dilution, should it be occuring. This can save you from a crankcase explosion which is not a pretty thing to happen.
Jeff D. said:What I was suprised by was the amount of Calcium,under the additive metals section.Apparently this is added to the oil??But why?
Orchard Ex said:What companies do you use and where do you buy your sampling kits? What is the cost of each kit/analysis.
FWIW - I've used a company called AOA in the past for airplane engines - looking to compare costs...
I can't tell how many hours you have on each sample, but a sample with few hours on it doesn't tell much. A longer trend of samples at 250 hours would do better. It's unfortunate you did not perform a base sample when you first purchased your rig. That would have given you a starting point to compare with. Another base sample everyone should have in their files is a base sample on the new oil you have just purchased. It serves the same purpose as an initial sample on new or used equipment.
That said, the iron in the 2nd sample is high enough to have made me suspicious and the silicon level is right on the edge where I would have had the boys start looking for induction leaks of other sources of silicon contamination. With a tapping noise, and the higher than normal iron reading, I would have opened the engine up. The cam lobes and rollers in that Mack evidently were not chrome plated as the chrome levels shown do not indicate a bit of it, not even from ring wear.
As others have noted, trends from a long period of samples really tell most of the story, but each individual sample also tells its own tale and once in a while you will see a sudden fuel dilution or glycol level, or a high reading elsewhere that indicates it needs immediate attention. That's where oil samples pay their way, indicating the sudden and potential catastrophic failures that are so expensive in terms of downtime, lost production, and repair or replacement cost.
Oil samples cost somewhere between 7 to 20 dollars each, depending if you buy sample packs in bulk or individually. I can not recommend them enough. However, even if a analysis from the sample lab comes with an "OK." You still need to sit back and reflect on how your equipment is used, where it's being used at, and who is operating it. There are so many things to consider beyond just the sample itself, and the more you know about all these things, the better decision you can make on a need to take action or let it slide.
NOTE ! I am in UK. The last batch of 20 from Terex cost me £8 @ Cardboard packing tube with small plastic screw top sample jar and sheet of paper
