Oils for swing gear
w2bstoned
canada
I don't have a service manuel, I was wondering what type of oil you guys recommend for the swing gear and planetaries?
Its a Cat e70
Thanks
bigbob
Lee,NH
I have a 94 307 and a 04 311CU. Change this oil yearly and use the Cat TDTO oil, weight dependant on temps.
LJMXUK
UK
Motocross practice track owner
I am using EP90 in my Slew gearbox on my Hitachi EX60URG. Is this correct?
surfer-joe
Arizona
Per Caterpillar, one should use 85W140 GO (Gear Oil) oil for mini-excavators in both the swing gearbox and the finals.
You don't have to buy it from Cat however, any number of companies produce a Cat spec oil that works just fine and is probably cheaper.
You can go to Cat's website and find their list of equipment and lube specifications here: http://www.cat.com/cda/files/1134980/7/F&F Application Guide PEWJ0074-02.pdf
gasfield315c
pineville, wv
build gaswell locations in the steeper than a mule
company i work for uses 50wt. in all our hoes finals and swing box
idler
georgia
In Georgia we used 50w for the swing and the finals per cat specs, you are in canada and who knows what type oil gear oil you will used.
