jimmyjack
found this video of a old caterpiller dozer. the machine looks like it runs as good as new
http://www.youtube.com/watch?v=A8BTT8mXZL8
Here's a question about those old cable dozers. Did they rely soley on the blade weight for down pressure, or was there some way with the cables they could pull the blade down? I've never really looked at how the cable systems worked on them...around these parts on farms still see a lot of old cats with cable operated blades.
Good video!!:thumbsup Here's a question about those old cable dozers. Did they rely soley on the blade weight for down pressure, or was there some way with the cables they could pull the blade down? I've never really looked at how the cable systems worked on them.
Thanks!!
I did see the cylinder up front on that one, but asked about the cable dozers after wrenchbender mentioned those kinds still down on the farm.Go back and look at the video again. 29 seconds into the video you will see a cylinder. This is not a cable operated dozer
I think that it is a Russian dozer.I have seen similar machines on the Russian heavy equipment sites.The number at the end of the film is probably the model number.That thing is really nose heavy,huh?Ron G
I ran cable dozers alot in past years, One benefit is they will go down as far as the cable is long not like hydraulic that rods out. Not that bad a system if everything is in good shape. DPGood video!!:thumbsup Here's a question about those old cable dozers. Did they rely soley on the blade weight for down pressure, or was there some way with the cables they could pull the blade down? I've never really looked at how the cable systems worked on them.
Thanks!!
Our old D7 2. war models has a winch controll like the one you are describing.
The handle operates the clutch on the back, the winch then rises the front blade. Small vinch, cable going over the driver and down front to the pullies at front. The pullies then lifts the blade. Looks wierd with the cable quide going from the back and over the dozer.
I don't realy now if this system is added later, but looks like original to me.
A very special machine to operate, dosen't have any down force on the blade though.
A popular machine for fine grading and levelling.(when still in use in the 60's and 70's)
It's in our engineer museum now. I had a very good day, when i got to ride all our old iron a day som years ago. (they need some exercise now and then)
