It's a "bitser" of a Cat genset. The engine appears to be a D318, which was released as a new design engine around 1947 - but I think I can see a plate with "D4600" on the bottom of the radiator side casting, below the "Caterpillar" wording.
There was an earlier model genset powered by the D4600 engine, which called the "46-30" model generating set - with the "46" being the engine reference and the "30" the output in kW.
However, when this size genset appeared with the new D318 engine powering it, the genset was then simply called the "D318 generating set".
So I'd say someone cobbled this genset together using an earlier genset radiator and the rest is largely D318 genset. There's a lot of "bits and pieces" missing from it.
I guess it was put together as a "typical Cat generating set" display, without any reference to historically correct components.
You learn something new every day, though - I had never heard of the Haida people before, but I had heard of the Queen Charlotte Islands, which are obviously now re-named to accommodate the original tribespeople.
