Over charging
Bigdog98vc
Wichita
I have a 1998 8042 skytrak that is over charging and cooking batteries.
But I've had the alternator tested 3 different times and they all say that the alternator isn't the problem.
Any ideas?
SR-71
NC
Measure the battery voltage while the unit is running. You should see approximately 13.8 to 14.2 volts. If the voltage is much higher than that, that's a problem, and it's probably the alternator. Also make sure all the battery connections are clean.
SR-71
NC
Oops, I misspoke on the voltage range. Assuming you have a 24v battery system, look for approximately 2.5volts higher than that when the unit is running.
