I have perkins engine on a backhoe and temperature builds to 100 degree Celsius within 20 minutes.
Have done the following so far without any improvement: changed water pump, blocked bypass from thermostat housing to water pump inlet, cleaned radiator, replaced fan, pressure test block and head, refaced block and head, rebuilt the engine with new gaskets.
Please assist because it seems I have almost everything with no success.
