cpmartin1989
Morning all, looking at the drawings of this machine it looks like it is called the safety valve. There is pretty much no info I have been able to find. Whenever I type something in I get a main pressure relief valve which is not the same thing from my understanding. I am curious what this valve is for. I removed it trying to see if that is where my internal leak within the valve control body was and I found an o-ring had damage to it. I replaced this valve until I can find that particular piece but after re-installing my boom now slowly lowers with/without the engine being on. I am curious to know if I maybe damaged the o-ring further when I removed this. Does anyone know what this valve is for? Can it be adjusted? There is an allen set screw under the i believe 19mm cap.
