Localmotion
Any Help Please?
Hi all
I got a diesel problem on my case CK28 excavator, which is fitted with a Kubota engine.
The fuel pump is leaking around the top of the injector, but I can't tell if it is the collar (below the split to the injector lines) or actually leaking around the base plate of the injector (where it meets the top of the pump using torque bolts).
Please take a look at this video of it...
YouTube - Leaking Kubota Injector
I've got two main questions:
1 - Is it possible to losen the collar from the base plate and if so does this affect timing?
2 - If I remove the torque bolts holding the base plant to the pump, will it affect the pump timing, and if so is there an easy way of retiming the pump afterwards?
Must admit to being a bit out of my depth here, but really need the machine back to work asap, and being in Spain we don't have any Kubota industrial engine workshops nearby.
Any help / tips / advice greatfully received.
Cheers, Ian. :drinkup
Hi all
