Location ?
Hello Deas ,
I would suspect the gradient to be more like .001 % on the coastal lands. From my job experiences. The surveyors working there could verify it.
The Prudhoe Bay tide fluctuation is only 1'.
The surface waters are stagnant, the ponds,lakes, saturate the tundra , liquify the soils and the magnetic pull , or gravitational forces , actually create, elongated water bodies, readily discernable from the air.
There are aberrations to that, as such, "pingos" or raised mounds of earth pepper the landscape much, as acne on a teenager. Sometimes 20' high. A danger to the low cruising helicopters in winter. Barely visible in the whiteness of the landscape.
I just got home from celebrating my Birthday, the band played Johnny Horton's "North to Alaska" .
I suspect I'll be busy grading somehwere by the Best Showtime. Steve Petraist from NC that wintered in the Antarctic, and is currently in Prudhoe has said he will be there. So Alaska will be represented.
Hello Randy,
Sounds like you have Wi-Fi , much more techno than us hinterland residents. Catching the red eye special for Vegas ??? Larry Graham is headed that way also.
The CIRI Hotel ??? Snuck in did you . LOL
Don't remember where I was .
Looks like the Sutton Coal Mine Reclamation, with the steaming pics.
I worked up there,prior, above you, for Al Johnson. Where the 80 meter cut was. Pushed that high bank down, took all summer. Exposed some of the old underground workings. Looked into the tunnels, real rich anthracite coal. All mined out. Psenak (sp)came in after us.
Well, enough for tonight.
