bobb, to give you the correct spec's I would need to know the engine series, if its the small 4 pot motor that is fitted to the volvo 140BLC excavator (D4D) the pumps are shimmed, there is a number stamped onto them, from this number its possible to set the correct shim hight, it might be a thought to also study the injector position, they have a dimple-dot on one side, this is fitted towards the valve gear ( if I remember correctly) and sets the spray holes in the tip to the correct part of the piston, it is possible to spill time the pumps.
tctractors
